EPRO AI NVR for OEM and ODM
https://linkingvision.com/eproainvr
The EPRO AI NVR is equipped with industry-leading software functions, perfectly supported by Intel, RK3588, and Novatek chips, designed to provide a comprehensive, reliable, and intelligent surveillance solution. Focusing on advanced software capabilities, which are fully optimized for Intel, RK3588, and Novatek chip platforms, it integrates high-performance video processing, flexible storage management, intelligent analytics, and seamless network connectivity, ensuring complete video recording, efficient monitoring, and convenient remote management. The chip support ensures stable software operation, enhanced processing efficiency, and full compatibility with all core software features. Suitable for residential, commercial, enterprise, and industrial scenarios of all scales, the EPRO AI NVR’s software system, backed by Intel, RK3588, and Novatek chips, delivers stable, efficient, and secure performance, while maintaining cost-effectiveness and easy integration with existing IP cameras and surveillance systems. EPRO AI NVR is ready for OEM and ODM.
Advanced N+1 Hot Spare Mode
A core reliability feature of the EPRO AI NVR, the software-enabled N+1 hot spare mode enables redundant backup for multiple EPRO AI NVR devices, fully supported by Intel, RK3588, and Novatek chips. One designated EPRO AI NVR acts as the standby unit, while N EPRO AI NVRs serve as active units. The chip platforms provide fast response capability, ensuring that when any active NVR fails, the standby NVR’s software will automatically take over all functions within seconds. This ensures zero downtime of the surveillance system, avoids video recording interruptions, and significantly enhances overall stability—critical for high-demand enterprise and industrial scenarios.
Advanced ANR (Automatic Network Replenishment)
A key highlight of the EPRO AI NVR, the ANR software ensures zero video loss even during network interruptions, with stable support from Intel, RK3588, and Novatek chips. When the network between the NVR and IP cameras is disconnected, the software triggers cameras to store video locally (via built-in SD card or local storage). Once the network is restored, the NVR software, backed by the three chip platforms, automatically synchronizes and supplements the locally stored video with zero latency, ensuring complete and continuous video recording without missing segments—ideal for unstable network environments.
