H5S Video Platform v20.0 is officially released! This milestone update dramatically enhances remote configuration capabilities for the ONVIF protocol , allowing comprehensive control over back-end device video streams, image adjustments, and OSD overlays directly from the platform interface.
Advanced ONVIF STG Device Configuration: This version seamlessly integrates deep configuration interfaces for ONVIF storage/standard device types. Users can now manage the following settings directly within the H5S platform without accessing the camera’s local web page:
Video Stream & Encoding Settings: Remotely adjust Stream Type, Resolution (e.g., 1920*1080P), Bitrate Type (CBR/VBR), Image Quality, Frame Rate (FPS), Maximum Bitrate, Video Encoding (H.264/H.265), Encoding Complexity, and I-Frame Interval.
Image Display Adjustments: Remotely fine-tune the camera’s Brightness, Contrast, and Saturation to optimize visual performance under varying lighting conditions.
OSD (On-Screen Display) Customization: Fully customize on-screen overlays, including Channel Name, Time Format, Date Format, OSD Font, and OSD Color.
Refined UI & User Interaction: Upgraded the “Video Source” management dashboard. The interface now features a clean, expandable multi-device tree on the left, paired with clear tabbed navigation (Video, Display, OSD) on the right for intuitive configuration and one-click saving.
Improved Protocol Compatibility: Enhanced protocol alignment with diverse third-party hardware manufacturers, significantly reducing configuration errors caused by proprietary brand variations.
