- The default username is admin, password is Vision@168, you must change the default password first time.
- Please download all the runtime support libraries from the following link:
Index of /download/h5stream/win/VisualC++Redistributable/
Please install in order, 2008, 2010, 2013, 2015-2019. If there is an installation failure, please update the operating system in the System and Security check update in the Control Panel. - If you want source code solution, you can check this HPro AI NVR with C/C++ source code offering and 4 channel free
Good ! but need more functions ![]()
